Denon 3803 .. Stand By
Discussion in 'AV Receivers' started by JohnChu, Jan 12, 2004.
  1. JohnChu
    JohnChu Stunt Coordinator
    Nov 26, 2003
    61
    As know the denon 3803 is always on standby .. when the power is off.. I am just wondering .. if I am removing or plugging conection to the receiver .. should I completly unplug the receiver ...or is it ok .. to do it .. when it is on standby?
  2. GregoriusM
    GregoriusM Second Unit
    Jul 31, 2000
    278
    As a rule, I turn EVERYTHING off when I connect or disconnect cables, that way you have no worries at all.
    The 3803 doesn't take long to repower up. It just does an internal check and then puts itself on standby.
    Greg
