Denon 3803 Remote Use
Discussion in 'AV Receivers' started by Erik.Ha, Jan 7, 2004.
  1. Erik.Ha
    Erik.Ha Supporting Actor
    Dec 24, 2003
    697
    I have a question regarding the Denon 3803. From the main unit, its possible to change the video selection using the "video select" button and the knob (for example you can listen to the tuner or a DVD source and set the monitor to output a different video source such as DBS or Cable.)
    Is it possible to use access this funtion from the remote control?
  2. Ed Moxley
    Ed Moxley Cinematographer
    May 25, 2003
    2,701
    Eastern NC
    Ed
    can't swear to it, but.......probably.
    If the remote for that is anything like the remote for the 2803, there's a bit of a learning curve to it. Good luck!
  3. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    Well, there is a remote code that will change the Video Select function and the 3803 will respond to it. But, no, it's not on the 3803's remote.
    Someone recently posted that a lower end Denon (1804 I believe) has the button on the remote. If you can go to a dealer, you may be able to learn it from one of these remotes.
    I obtained my code from a $25 One-For-All universal remote. These remotes can "create" remote codes by entering code numbers to emulate specific models/brands.
    Checkout this site for more OFA info...
    http://www.hifi-remote.com/ofa/index.shtml
  4. Erik.Ha
    Dec 24, 2003
    697
    WOOOOOOOHOOOOOOOOOO!!!!!!!!!!
    Im doing the snoopy dance all over the house!!!!
    I went to the page you suggested and was completely flumuxed... Then I read that "all in ones are often packaged with other devices." I remembered that crappy remote that came with my digital cable converter...
    After tearing the house apart looking for it, when I finally found it, it didnt look ANYTHING like the remotes shown on the website, but I figured... "WHAT THE HELL???" I started following the instructions for setting an advanced button, and the led started blinking just like it said it should....
    To make a long story short, IT WORKS!!!! Now I've got the code so I can program my Sony av2100!!!!
    YOU DA MAN!
  5. Chuck Kent
    May 29, 1999
    983
    Great! Glad to help.
    I use the Video Select command daily in my setup. I'd hate to give it up...
  6. GarAlb
    GarAlb Stunt Coordinator
    May 28, 2003
    53
    I used my old Denon AVR-2700 remote to "learn" the video select function on to the 3803 remote. Works fine[​IMG].
  7. Erik.Ha
    Dec 24, 2003
    697
    I cant beleive they dont have this button on the remote...
    Same goes for the Rec-out, but thats less of a problem... Is there a remote code for Rec out? I didnt see one on the Universal Remote page mentioned.
  8. Chuck Kent
    May 29, 1999
    983
    No, I haven't seen a REC out selection remote code.
    Denon did release extended codes for several of their line (including the 3803) for things like direct volume jumps to -20, -40 and 0 db. You can also get codes for direct mode switching, like going directly to Mono Movie, DPL II Music and so forth. Also Zone 2 control for direct input selection and 3 volume presets. Lots of additional stuff. But no REC input changing...
  9. Erik.Ha
    Dec 24, 2003
    697
    How does one get the "extended Codes"?
  10. jeff_coil
    jeff_coil Stunt Coordinator
    Dec 3, 2002
    157
    Erik, Did you use the device 0160 and 218 to get the vid select to work? My 3803 doesn't respond to any of the advanced codes I have tried with the 3803 [​IMG] I have used the same procedure to program other codes to my OFA then to my MX500.
    Here is a listing of the advanced codes I came up with
    Device2=AUDIO_0160
    OBC EFC
    072 162 ZONE1 TUNER
    073 158 ZONE1 PHONO
    074 160 ZONE1 CD
    078 161 ZONE1 DVD
    079 157 ZONE1 VDP
    082 096 ZONE1 TV
    083 092 ZONE1 DBS/SAT
    084 099 ZONE1 VCR-1
    085 095 ZONE1 VCR-2
    086 097 ZONE1 VCR-3
    087 093 ZONE1 V.AUX
    088 226 -
    091 220 ZONE1 TAPE-1
    092 227 ZONE1 TAPE-2
    093 223 ZONE1 ON/OFF
    101 255 ZONE2 VOLUME DOWN
    102 001 ZONE2 VOLUME UP
    106 128 PURE DIRECT
    115 060 INPUT MODE AUTO
    116 067 INPUT MODE PCM
    117 063 INPUT MODE DTS
    121 190 MAIN ZONE ON
    122 192 MAIN ZONE OFF
    123 188 MULTI ZONE1 ON
    124 195 MULTI ZONE1 OFF
    125 191 MULTI ZONE2 ON
    126 193 MULTI ZONE2 OFF
    193 022 POWER
    194 024 FL LEVEL UP
    195 020 PHONO
    196 027 CD
    197 023 TUNER
    199 021 FL LEVEL DOWN
    200 154 DBS/SAT
    201 150 TV
    202 152 VDP
    203 148 FR LEVEL UP
    204 155 V.AUX
    205 151 VCR-1
    206 153 VCR-2
    207 149 VCR-3
    208 090 FR LEVEL DOWN
    210 088 MD/TAPE-1
    211 084 TAPE-2
    213 087 CINEMA EQ ON
    214 089 SR LEVEL UP
    215 085 SR LEVEL DOWN
    216 218 VIDEO SELECT
    217 214 CINEMA EQ OFF
    219 212 MULTI
    220 219 INPUT MODE ANALOG
    221 215 CURSOR RIGHT
    222 217 STATUS
    223 213 ON SCREEN
    224 250 ENTER
    225 246 POWER ON
    226 248 POWER OFF
    227 244 DVD
    228 251 DOLBY SURROUND
    229 247 SW LEVEL DOWN
    230 249 DSP SIMULATION
    231 245 SB/SBL LEVEL UP
    234 120 TEST TONE
    235 116 SB/SBL LEVEL DOWN
    236 123 SW LEVEL UP
    237 119 SPEAKER
    240 058 MUTING
    241 054 MASTER VOLUME+
    242 056 MASTER VOLUME DOWN
    243 052 SL LEVEL UP
    244 059 SL LEVEL DOWN
    245 055 CENTER LEVEL UP
    246 057 CENTER LEVEL DOWN
    247 053 SBR LEVEL UP
    248 186 SBR LEVEL DOWN
    249 182 TONE DEFEAT ON
    250 184 TONE DEFEAT OFF
    251 180 SB:MATRIX ON
    252 187 SB:NON MATRIX
    253 183 SB:OFF
    Device 4=VCR_0076
    129 006 WIDE SCREEN
    130 008 SUPER STADIUM
    131 004 ROCK ARENA
    132 011 JAZZ CLUB
    133 007 CLASSIC CONCERT
    134 009 MONO MOVIE
    135 005 MATRIX
    138 136 THX ULTRA2 CINEMA
    139 132 THX MUSIC MODE
    140 139 THX SURROUND EX
    141 135 DTS NEO:6 CINEMA
    142 137 DTS NEO:6 MUSIC
    143 133 DOLBY PL‡U CINEMA
    144 074 DOLBY PL‡U MUSIC
    145 070 DOLBY PL‡U EMULATION
    147 068 DTS ES MATRIX
    148 075 DOLBY DIGITAL EX
    Device12=AUDIO_0004
    127 189 CURSOR LEFT
    128 010 ALL BASS DOWN
    129 006 DTS SURROUND
    130 008 SURROUND BACK ON/OFF
    131 004 MASTER VOL. PRESET1(0dB)
    133 007 MASTER VOL. PRESET2(-20dB)
    134 009 MASTER VOL. PRESET3(-40dB)
    135 005 ZONE1 VOL. PRESET1(0dB)
    136 138 ZONE1 VOL. PRESET2(-20dB)
    137 134 ZONE1 VOL. PRESET3(-40dB)
    138 136 ZONE2 DBS/SAT
    139 132 HOME THX CINEMA
    140 139 ZONE2 VOL. PRESET1(0dB)
    141 135 ZONE1 VOLUME UP
    142 137 ZONE1 VOLUME DOWN
    143 133 ZONE2 PHONO
    144 074 ZONE2 CD
    145 070 ZONE2 TUNER
    146 072 ZONE2 VDP
    147 068 ZONE2 V.AUX
    148 075 ZONE2 VCR-1
    149 071 ZONE2 TAPE-2
    153 198 ZONE2 VCR-2
    154 200 ZONE2 VCR-3
    155 196 ZONE2 TV
    156 203 ZONE2 TAPE-1
    157 199 STEREO
    158 201 DIRECT
    159 197 ZONE2 VOL. PRESET2(-20dB)
    160 234 SYSTEM SET UP
    161 230 SURROUND PARAMETER
    162 232 ZONE2 VOL. PRESET3(-40dB)
    163 228 CURSOR UP
    164 235 CURSOR DOWN
    168 106 5CH/7CH STEREO
    169 102 2CH PLAY(INPUT CH)
    170 104 MULTI CH PLAY (INPUT CH)
    172 107 AUDIO FUNCTION
    173 103 VIDEO FUNCTION
    175 101 CH SELECT
    176 042 CH VOLUME UP
    177 038 CH VOLUME DOWN
    181 039 INPUT MODE EXT.IN
    182 041 INPUT MODE
    183 037 ALL TREBLE UP
    184 170 ALL TREBLE DOWN
    185 166 TUNER SHIFT A
    186 168 TUNER SHIFT B
    187 164 TUNER SHIFT C
    188 171 TUNER SHIFT D
    189 167 TUNER SHIFT E
    190 169 ZONE2 DVD
    191 165 ALL BASS DOWN
    193 022 TUNER PRESET CH 1
    194 024 TUNER PRESET CH 2
    195 020 TUNER PRESET CH 3
    196 027 TUNER PRESET CH 4
    197 023 TUNER PRESET CH 5
    198 025 TUNER PRESET CH 6
    199 021 TUNER PRESET CH 7
    200 154 TUNER PRESET CH 8
    204 155 TUNER MEMORY
    205 151 TUNER SHIFT
    213 087 TUNER PRESET DOWN
    214 089 TUNER PRESET UP
    215 085 TUNER BAND
    216 218 TUNING MODE(AUTO/MANUAL)
    217 214 TUNER TUNING UP
    218 216 TUNER TUNING DOWN
    223 213 DIMMER
  11. Chuck Kent
    May 29, 1999
    983
    Jeff: Are the 0076 codes the ones you're trying? From what I understand, there are no current One For All remotes that support 0076 out of the box. The only way you can generate the codes is to use the JP1 PC interface/program.
    This is the method I originally used. A kind JP1 guru helped me over at remotecentral.com and the codes worked 1st time out. Besides the JP1 method, I also have the codes via Home Theater Master (for the MX-700.) I use an MX-500 daily and I have taught some of the codes to it. I have IRClone for the MX-500, and if you do too, I could e-mail you some of the main codes.
    Erik: As Jeff has already noted, the extended codes are obtained via PC and a PC-connectible remote. You can use a JP1 enabled One For All, one of the MX series of Home Theater Master, a Pronto (or Pronto look-a-like) and a few others like that. Remotecentral.com has the info (along with the JP1 website I listed above) and the help on how to start working with PC connected remotes.
  12. jeff_coil
    Dec 3, 2002
    157
    Thanks Chuck, I was trying the 0160 codes. I have the JP1 stuff and have never tried it out until yesterday with no luck but haven't given it a real hard go at it. I was able to create a new device and get it into the remote it doesn't appear real difficult but just trying to find the correct information is half the battle. Do you have the JP1 upgrade file you could send me?
    You know I am about this close in ordering the MX 700 how is the programming interface for that?
    Thanks Jeff
  13. Erik.Ha
    Dec 24, 2003
    697
    I used the 0160 and 218 codes and it worked fine... the other codes (the denon codes that are in my remotes manual and the other one listed at the OFA website) DIDNT work....
    Luck of the draw I guess?
  14. jeff_coil
    Dec 3, 2002
    157
    Well I got it all working thru the JP1 stuff! Yea! Actually I got every advanced code to work that I have. I did notice that some of the EFC's are incorrect in the listing I posted above but all the OBC are correct.
    Chuck my main problem I was having was I had the wrong remote selected in the IR.exe errrr that cost my like a whole day once I selected the correct remote everything worked great- go figure huh
    Thanks everyone
    Jeff
  15. Chuck Kent
    May 29, 1999
    983
    Good to see you got it going! I use some of the direct mode switches and a couple of the volume presets every day.
    It's too bad Denon can't find a way to put all of these commands on all of their remotes. But if memory serves, Denon isn't alone. Yamaha has extended codes that they don't put on their factory remotes either...
