Denon 3803 and Component output
Discussion in 'AV Receivers' started by GeorgeTed, Jul 26, 2003.
  1. GeorgeTed
    GeorgeTed Auditioning
    Jul 10, 2003
    10
    I think I'll be getting the Denon 3803. The item that pushed me over the fence is the Component output to the TV.
    My equipment will be rather far from the TV (about 25ft) and I want to run only one cable.
    Will there be any degradation in my High Def signal coming from my cable box through the Denon to my TV?
    thanks...
    g
  2. Michael Mathius
    Michael Mathius Supporting Actor
    Nov 12, 2000
    718
    George:
    I have been using a 25 foot cable connecting my Denon 3803 to my Sony HS10 projector with no noticeable signal degradation in hdtv or dvds.
    Michael
  3. GeorgeTed
    Jul 10, 2003
    10
    Thanks...I just needed to get some input from somebody using the 3803...
    other than that...how do you like this unit?
    g
  4. hitendra
    hitendra Extra
    Jul 28, 2003
    21
    Normally, till approx 30 ft, there should be no visible degradation if you are using a good quality cable.
    BTW, any reason why you don't want to connect your dvd player directly to the TV instead? Is it that your dvd player doesn't have component output? Just curious
