Denon 3802 video split.
Discussion in 'Archived Threads 2001-2004' started by Stephen Dodds, Oct 11, 2001.
  1. Stephen Dodds
    Stephen Dodds Second Unit
    Aug 29, 1998
    354
    I ma one of those who like to watch video sources while I listen to CDs.
    On the Denon 3802 is there an easy way to assign a video source to any digital input.
    I know you can do it by pressing the Video Select button on the receiver, but it doesn't continue if you switch between inputs, and there is no button on the remote.
    Or am I extra dumb today.
    Steve
  2. Stephen Dodds
    Aug 29, 1998
    354
    OK, I am dumb. I can do this by assigning a digital input to VDP for example, however it appears you cannot assign a digital input to multiple names, ie have coax be the digital input for both CD and VDP?
    Correct?
    Steve
    P.S. Anyone know if US 3802s will switch PAL signals?
    [Edited last by Stephen Dodds on October 11, 2001 at 03:34 AM]
  3. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    Steve: You are correct. Only one assignment per digital input.
    There is a way around the Video Select by using your universal remote control (I'm making a leap of faith that you have one.) The One-For-All Cinema 7 (or Radio Shack 15-1994) IR remote control can generate the code to change the Video Select. The device is 0160 and the code is 474. You can then teach the code to your universal from the C7/1994.
    If you are running a Pronto, I imagine that someone has the code available to download.
    (FWIW, Denon used to put the button on the remote. For whatever reason, they don't anymore. But the function still works. Also, Status, (the receiver display - device 0160 and code 473) lets you verify the actual format being decoded. Handy once in a while.)
    (Don't know about the PAL video??)
    [Edited last by Chuck Kent on October 11, 2001 at 07:58 AM]
  4. James_T
    James_T Stunt Coordinator
    Jul 9, 2000
    89
    I just purchased a Denon 3802 and was about to ask the very same question. As it turns out, I have a Pronto, so...
    Does anyone here have the code for the pronto on a CCF they could lend me? I'd hate to sift through all those files at remotecentral.com to find one.
    Thanks.
