Don Morrison
- Jul 1, 2002
Ok. So I bought a 3802 a few weeks ago. Can't be much happier. Just have a quick question though. It is hard to get any weak FM signals throughthe tuner so far. I know that it says that you can hook up a larger attenna than what is supplied with it... but how do you do that? It will only let me plug in the indoor antenna, and the coax adapted that they supplied with it wont attach to the back of the recevier. How do I make this work??
