Denon 3802 Systems Menu How to Access?
Discussion in 'AV Receivers' started by Peter L, Jul 17, 2004.
  1. Peter L
    Peter L Extra
    Jan 16, 2002
    19
    Hi,
    I can't seem to access the systems menu of my denon 3802. When I hit setup on the denon remote nothing happens. The LED on the remote says AV setup but nothing shows on the screen.
    I have component out from my DVD player to 3802 DVD in, and component out from 3802 to my HDTV component in.
    I can use the dvd player no problem just not the systems menu. Please help!
    51" Sony KP-51HW40
    Denon 3802
    Panasonic RP91
    Peter
  2. Marvin
    Marvin Screenwriter
    Apr 9, 1999
    1,480
    41
    Marvin
    Does "component out" relay the OSD signal? Is the DVD player on (and possibly overriding the OSD signal)? If so, maybe powering off the DVD would work?
    Does the display on the receiver itself show anything when you go into system setup?
    Isn't there another "monitor out" or something like that on the Denon that you could hook up to a different input on your TV?
  3. Cary_H
    Cary_H Second Unit
    Jun 7, 2003
    280
    Just run a cheap pair of composite cables to a free video input on your set from your Denon.
    Select this input on the set's menu when you want to get the Denon's OSD.
    The OSD for the 3802 isn't supported over a component connection.
  4. Thang_N.
    Thang_N. Stunt Coordinator
    Aug 23, 2002
    64
    I just use a cheap S-Video for mine...Make sure you go to that output you have hooked up to your TV.. Hope that makes sense.
