Denon 3802 question
Discussion in 'Archived Threads 2001-2004' started by EarleD, Nov 25, 2001.
  1. EarleD
    EarleD Supporting Actor
    Aug 27, 2000
    728
    3
    I have been thinking about adding a dedicated rear sub to my system and I have a question.
    I have all speakers set to small and the receivers crosover set to 80hz.
    If I get a powered sub and run it from the rear preamp outs will the sub see a full range signal(even tough the rears are set to small) or does the preouts also send a filtered signal?
    Earle
  2. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    The pre-amp outputs are just before the amps. So, the level trim and crossovers are fully implimented.
    If you want to use a sub with any pre-amp output (except for the sub output), you must set the speaker size setting to "Large".
  3. EarleD
    Aug 27, 2000
    728
    3
    Chuck
    thats what I thought. Thanks for the quick answer
    Earle
