EugeneM
Grip
- Dec 5, 2001
This is my current setup:
2 Kef Q75 as mains
Specs:
Cabinet Design - 3-way, 3-driver + ABR bass reflex
Crossover frequencies - 120Hz, 3.3kHz
Frequency Responce +/-* 3dB - 36Hz - 20kHz (at 15 degrees gorizontally off axis)
LF Corner - 6dB - 33Hz
Sensitivity - 2.83v @ 1m - 91dB
Maximum output - typical in room - 114dB
Amplifier requirements - 10-200W
Impedance - 6ohms
1 Q95C as center (85Hz - 20kHz), 2 Q15 as surrounds (50 Hz - 20Khz)
There is also home-made sub that will be replaced with another one, didn't make
a decision on this one yet.
This is driven by Technics SA-AX6(receiver) / AC-500D (DD/DTS decoder) combo.
I mostly watch DVDs, player is Pioneer DV-440, connected to AC-500D through
coax digital out. DV-440 doesn't have built-in DD/DTS decoder.
I know my speakers will benefit from the better receiver, but 3 yrs ago only
other option was Yamaha A1( ? model #), and it was way too expensive.
Now I am considering replacing Technics combo with Denon 3802.
In my search I found a post saying that 3802 crossover frequencies are not very
useful - 80, 100, 120 Hz ( 4802 adds 40 and 60 Hz to this list)
Now look at the specs of my speakers - mains go down to 36 Hz, surrounds -
down to 50 (center doesnt go far down thou). The lowest possible crossover
frequency on 3802 is 80 - way above 36 and quite above 50. Does it mean that
3802 is not good enough for my speakers? I can't believe this is the case.
A lot of people seem to have speakers of similar or better quality and give
qood reviews for 3802
4802 is about $1000 more, it costs as much as all my speakers together, and
I dont think this is a proper price ratio (if that logic makes any sence at all. I mean
you wouldn't drive $500 speakers with $1000 receiver, right?)
I must be missing something.
Please explain where I am wrong.
2 Kef Q75 as mains
Specs:
Impedance - 6ohms
