Denon 3802 and FM reception ???
Discussion in 'Archived Threads 2001-2004' started by Eric Stuckey, Oct 19, 2001.
  1. Eric Stuckey
    Eric Stuckey Second Unit
    Mar 24, 1999
    421
    Eric Stuckey
    I have the 3 foot intina that came with the 3802 and I was wanting to know If any of the Intina's in the $20-40 range would work BETTER or the same?
  2. RyanDinan
    RyanDinan Stunt Coordinator
    Oct 25, 2000
    249
    I'd like to know how to correctly connect the antenna to the receiver.... [​IMG]
    The receiver has the F-type connector on the back, and comes with an antenna and an adapter. How do you connect the antenna to that little adapter thingy? Plus, the adapter won't fit onto the F-connector on the receiver...it's too small or something...
    Sorry if this is a completely stupid question, but all my old receivers had the wire and screw-down knob - kinda like speaker posts..
    -Ryan
  3. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    ArthurL
    Ryan, the antenna that came with my 3802 is a thing white cable with a, say, half inch long grey tip on one end. The grey part slips right over the center post of the F-type connector on the back of the receiver.
