Denon 3801 LFE setup? (1 Viewer)
J
John Morris
What is the difference on the setup menu between "LFE" and "LFE + Main" . Does "LFE + Main" mean that it will pass all sub 80Hz signals to both the main front speakers AND the subwoofer?
Thanks for your help!
Take Care,
merc
Steve_D
I'm pretty sure it means the sub will either play LFE only, or it will play LFE + 80HZ and below from the mains, reinforcing the mains. If I remember right from my setup (on Saturday), that menu is only enabled if you select mains large sub yes.
So yes, I concur with your interpretation, and that's what it is with the poor manual...
Link Removed
[Edited last by Steve_D on July 24, 2001 at 10:55 PM]
S205449
