Denon 2900 v.s. 2800MK2
Discussion in 'Playback Devices' started by David Giesbrecht, Jun 18, 2003.
  1. David Giesbrecht
    David Giesbrecht Second Unit
    May 28, 2001
    306
    Is there any difference in these players as far as video performance goes. I'm not really interested in DVD audio or SACD play back. I don't think the 2900 has DCDI, will the 2800 look better?
  2. Luis S
    Luis S Supporting Actor
    May 7, 2000
    637
    Stay away from the 2800/2800 MKII line. Not worth the hassel IMHO. They were buggy from the get go and its pretty damn difficult to get one that works well from what Ive heard. YMMV of course and you may get lucky but its something you should keep in mind any way. I waited and bought the 2900 and it is one SWEET machine. Absolutely stunning picture and sound,well worth the price to me [​IMG] Hope this helps.
    Later,
    Luis S
  3. David Giesbrecht
    May 28, 2001
    306
    Luis
    Do you use the 4:3 shrink function, and if so does it work well.
  4. David Giesbrecht
    May 28, 2001
    306
    bump
  5. Luis S
    May 7, 2000
    637
    Oops! Sorry I didnt get back to you David! :b But to answer your question, your refering to watching non-anamorphic material right? If thats it then no, I couldnt tell you how the shrink and zoom is.I dont have anything really to try it out with. I'll see if I can find something though and give it a shot. I'll let you know what I find out.
    Later,
    Luis S
  6. David Giesbrecht
    May 28, 2001
    306
    anyone else? don't forget me!
  7. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    Do NOT buy the 2800 MKII.
    It is not reliable - freezes, skips, audio drop-outs, etc. are all too common.
    Furthermore, it is plagued with the worst case of the chroma bug I have ever seen.
    The 2900 is 100 times better. If you want the Silicon Images decoding engine, it is the only WTG.
    Ed
