Denon 2807 & Directv HDMI
Discussion in 'Beginners, General Questions' started by David_Miller, Jul 25, 2006.
  1. David_Miller
    David_Miller Auditioning
    Jul 24, 2006
    8
    Hi all, first post. Hope I don't mess this up too much.
    Just upgraded to an HDTV and after reading some reviews purchased the Denon 2807 to control everything. I'm not a serious audiophile or anything, just like high quality merchandise and have always had good results with Denon products.
    Anyway, on Friday the Directv guy showed up and delivered my HD DVR and installed the right dish and antennae and I was then left to my own devices. Here's where it went screwy:
    I hooked up the Directv box to the 2807 using HDMI and HDMI from the 2807 to the TV. I can get sound through the TV speakers if I set the Denon settings that way, but I can't get any sound through the surround sound speakers set up this way (I had the audio in set to HDMI and the out to the AMP).
    When I connected an optical cable from the Directv box to the 2807 and set that input on the 2807 I get sound and picture.
    Questions:
    (1) Shouldn't I be able to use the HDMI for sound for the surround sound?
    (2) If so, what setting am I screwing up?
    (3) Does it really matter? Is the optical as good as the HDMI connection? (Other than the need to use one more cable which HDMI was supposed to eliminate....)
    (4) If this is a problem (for all I know this is how it is supposed to work but that seems wrong) is the problem likely with the 2807 or the directv box? My hunch is that it is with the 2807 because when I go straight from the directv box to the tv I get sound (and when I set the 2807 to send sound to the Tv I get sound from the TV speakers).
    Thanks for any help you can provide!
  2. Chad_K
    Chad_K Extra
    Jul 6, 2006
    20
    As an installer I never use HDMI for audio. In my opinion it is better to use Toslink or Digital Coax. You have to remember that there are still bugs with the HDMI so that is my I do it this way every time.
  3. David_Miller
    Jul 24, 2006
    8
    Chad,
    Thanks for the response and that is how I have it hooked up now, but I guess I am concerned about the other issues I raised in my post which get at whether I am looking at a bad piece of hardware.
    Anyone have any thoughts?
  4. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    An optical connection for 5.1 audio either from digital cable or satellite is fully as good as HDMI. It may turn out (and given the specifications it is likely) that some of the newer audio formats will require something more than Toslink, but until you purchase one of the new HD players, you won’t have to be concerned with that issue.
  5. Louisp
    Louisp Stunt Coordinator
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    I too have the 2807 and DTV HD. To effectively run the DTV HD H20 or HR20 run components from the receiver to the 2807 then HDMI from the 2807 to your television.
    In my case so far I am not at all happy with the 2807 when used with Directv. The volume level from station to station is absurd.
    What is your opinion of the 2807?
