Denon 2805 to auto eq or not
Discussion in 'AV Receivers' started by Mike_J_Potter, Jul 5, 2005.
  1. Mike_J_Potter
    Mike_J_Potter Second Unit
    Dec 26, 2003
    262
    I just upgraded from a old Harmon kardon AVR125 to a denon 2805. I was wondering is the Auot EQ worth it or should I calibrate it with my Meter and Avia? The speakers are Infinity Entra .5 sats (front and rear) a entra center, and a SVS pb10-ISD. If I do auto eq I am planning to check the sub calibration anyways to make sure its not too hot. Once I get the entertainment center put back together, I will play around with it and see what it is like, but your experiences would be helpful.
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Go ahead and do the auto-eq, well worth it in my experience. If you don't like it you can turn it off.
  3. Mike_J_Potter
    Dec 26, 2003
    262
    I tried the auto eq today and kept on getting an error. I am assuming it is since I am running the system in 5.1 with the other 2 speakers set to the zone 2 to make it test in 5.1. I still get an error.
  4. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    What kind of error were you getting? I run 5.1 on my 3805 and the auto EQ does try to access the missing channels but it doesn't stop the EQ function.
    Mort
  5. Mike_J_Potter
    Dec 26, 2003
    262
    Got it! Turns out I forgot to switch the input on the receiver to the mic and not aux. doh! Now to wait for the AC to turn off so I can get a accurate measurement.
