Corey Holter
- Jul 5, 2002
Does anyone know if the new Denon 2803 and/or 3803 will have more than two component switching? The 4802 and 5803 both have thee component in, with one component out. Also, they are rated at 50MHz and 100MHz respectively on the component switching. The current 3802 has only 27MHz for component switching, which I've read is fine for DVD, but not great for HDTV.
Bottom line is if either of these receivers has three component in and higher MHz for component switching, it may be better for me than the 3802.
Thanks.
Thanks.
