Denon 2802 Users
Discussion in 'Archived Threads 2001-2004' started by Frank Kanyak, Sep 14, 2002.
  1. Frank Kanyak
    Frank Kanyak Stunt Coordinator
    Feb 28, 2002
    240
    With my Denon 2802 even though it has pre-outs for 7.1 can I somehow wire my rear center surrounds to a 4ohm load or to a 16 ohm load. I have a great deal on another pair of S-26's that I can't pass up. Will running a pair of rear centers drain power from the rest of the channels? Any advice is appreciated. I do not know if my old Technics receiver would blend in for the rears if I would go the pre-out way. Thanks!
  2. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    You can wire them in series it no problems. Positive from reciever to pos on speaker1. neg on speaker 1 to pos on speaker 2. neg on speaker 2 to neg on reciever.
  3. Frank Kanyak
    Feb 28, 2002
    240
    So has anyone else done this? What are the main concerns that I need to worry about if any? Thanks Bobby!
  4. SteveMo
    SteveMo Stunt Coordinator
    Jun 19, 2002
    116
    Since the manual doesn't say you can do that I wouldn't try it but thats just me. You need two amplifiers to handle the preouts that can output a 4ohm or 16 ohm impedence. You could also use one amp like I am right now and hook the other speaker up to the 2802 but it needs to be 8 ohm.
    Running the wrong speaker can actually hurt the reiciever I think.
  5. Bobby T
    Mar 13, 2001
    583
    I ran my 2802 like this for about 7 months. The reason I stopped is because my dealer gave me all of my money back towards a 3802. When you wire in series the receiver sees a 16 ohm load which the manual says you can run. You should repost this question with the title Can I safely wire speakers in series on a 2802? That will get you more responses.
  6. Frank Kanyak
    Feb 28, 2002
    240
    Thank you!
