DonRo
Grip
- Dec 7, 2003
My Denon DVD-2200 and AVR-1804 arrived yesterday and I will hopefully be hooking them up and doing the calibration with a reference DVD this weekend. I read in another thread (“denon receiver” from 12 January) that the 2803 cannot output digital input to zone 2.
I assume by “zone 2” they are referring to the “B” speaker connections? I was planning on connecting my DVD-2200 to my 1804 via digital-coax and the 5.1 “external in” only (and running the video directly to my TV.)
Note: I was told by a Denon support service rep (here in Germany) that in order to take advantage of SACD you have to use the 5.1 connections because of decoding issues. There is also a reference note to this affect in the user manual.
The problem is I plan to use the 2200 to play audio CD’s (plus I will also want to output digital radio reception via a SAT receiver in the near future) ...and I will want that output to go *stereo* to my Klipsch’s (will connect to B) in another room. Does this mean I need to make a 3rd “audio” connection between the 2200 and 1804 to get an analog input for my “B” speakers? Can this cause problems when the same device (in this case my 2200) is sending output to 3 different input channels simultaneously?
Obviously the signals from my turntable and tape deck won’t be a problem. Can anyone set me straight here?
A sincere thanks in advance for your time and assistance.
Home Theater “newbie” Don currently residing in Germany
