Chris A H
- May 10, 2002
Found this on a german website:
http://www.hirsch-ille.de/denon/avr1803.html
Here is the Google translation of the above german description:
Denon AV aV-Receiver Avr-1803
Avr-1803, 7-Kanal-A/V-Receiver with Dolby digital, Dts it and pro Logic ii-decoder,
Fulldiscrete 7-Kanal-Endstufe with identical power output and circuit interpretation,
7 x 150 Watts (6 ohms, 1 kHz, 0,7 % rattle/clink),
Special output stage transistor with internal operating point stabilization,
DTS Extended Surround (IT) Discrete 6,1 & Dts it matrix 6.1-Decodierung,
Dolby digital decoder with 6.1-Surround-Modus for 100 % compatibility with TRACKS of sound of film and
Music in Dolby digitally Surround ex, also existing 5.1-Software can be shown in the ex mode,
Dolby pro Logic ii-decoder (modes: PLII Cinema, PLII Music with options, pro Logic),
Dolby pro Logic ii-decoding on digital level,
DTS-Neo:6 Cinema & DTS-Neo:6 Music Stereo to Surround decoding,
Dd sports club digital circuit, similar to DEVICES SHARC 32-Bit-Fliesskomma-DSP,
24-Bit/96 kHz A/D transducers, similar to DEVICES Ad-1854 24-Bit/96-kHz-D/A-Wandler for all channels,
Digitally interface receiver for signals to 24 bits and 96 kHz, wide-band circuit interpretation for those
next generation of highly soluble clay/tone formats, Direct mode for best quality of similar sources (evasion of the digital section),
Cinema Equalizer, music Surround programs inclusive 5-/7-Kanal-Stereo, tone control, video SELECT function,
Photograph selector switch, user friendly screen menu, personnel MEMORY plus,
Supports an additional hearing zone with a Stereo Vorverstaerkerausgang, flexible configuration of the inserted achievement amplifiers
the Surround bake channels (Surround bake or multi-zone), UKW Stereo /MW uKW-Stereo-/MW-Tuner also
40 station memory and RDS with radio text, 2 color component entrances and 1 exit, compatibly with wide-band
Signals of progressive Scan DVD and HDTV, 5 s-video and FBAS (Composite) entrances, 3 s-video and FBAS
(Composite) exits, of it 1 monitor exit, wide-band one 7.1-Kanaleingang (100 kHz) for future multi-channel formats such as DVD audio, preamplifier exits for 7.1 channels, adjustable Subwoofer Uebernahmefrequenz (80, 100 and 120 Hz), 4 freely zuordenbare digital entrances (1 coaxially, 3 optically) and 1 optical digital exit, 8 pair similar entrances (inclusive PHONO (mm)) and 3 pair of exits, two pairs of connections for Surround loudspeaker, sturdy loudspeaker c-clamps for all connections, headphone exit,
A switched mains connection socket,
Pre-programmed and adaptive multi-function remote maintenance with LCD display and background lighting,
Dimensions in mm (B x H x T) of 434 x 171 x 416,
In gold and black available
