Denon 1803 Channel Adjustment
Discussion in 'Archived Threads 2001-2004' started by William Wu, Nov 5, 2002.
  1. William Wu
    William Wu Auditioning
    May 22, 2002
    4
    Hi All,
    Does anyone know how, on the Denon 1803 receiver, to adjust the volume on the different channels separately (center, front, surrounds...)? I could have just missed it in the instruction manual, but I didn't think so. I can figure out how to adjust the LFE fine, but not the other channels (independently at least).
    Thanks for the help!
    William
  2. Justin H
    Justin H Stunt Coordinator
    Sep 30, 2002
    167
    While you have some audio running, say you're watching TV in PLII, just hit the enter button (on the bottom of the remote in the center of the up, down, left, right buttons) repeatedly and it will scroll through the individual volume adjustments. To adjust simply hit 'enter' then 'up' or 'down', 'enter' then 'up' or 'down' and so on.
  3. William Wu
    May 22, 2002
    4
    I will try that when I get home from work tonight!
    William
  4. dan levatan
    dan levatan Extra
    Aug 25, 2002
    15
    I just recently purchased an 1803.
    Go to page 41 of the instruction manual.
