Joe Mihok
- Dec 14, 2003
I listen to music in "DIRECT" mode and I run it this way because I assumed this bypasses the subwoofer, however it's not. I'm kinda tired of going up to the sub and manually shutting it off when I want to listen to music. Anyone know why this is happening ? Also, another funny thing is happening. When I tell the amp I have no sub (in the system setup), the subwoofer is still being used ...... I have no idea why this happens either. I have the sub hooked up through a high quality RCA cable with a y-splitter. The sub is a DAVID 250 D-BOX.
Some other strange things occur with the sub and reciever as well. For some reason I set the crossover freq on the Denon to 80hz, yet it's still sending bass above the 80 Hz mark to the sub (i assume this because the sub is producing sound above 80hz). The sub's xover is set to max as I thoguht the Denon would do the cut-off ... however it is not and I now am forced to manually tune the sub to 80hz via the "x-over knob".
Can anyone tell me why this is happening ? Thanks a bunch
