Denon 1602 volume setting -60 to +18
Discussion in 'Archived Threads 2001-2004' started by MichaelWRX, Jun 19, 2002.
  1. MichaelWRX
    MichaelWRX Auditioning
    Jun 18, 2002
    9
    I have a question,
    I have the 1602 and read and know that the volume setting goes from -60 to +18. This is when you do not increase any one channels volume in the setup otherwise the +18 will reduce by the amount of the increase over 0. Ie if you increase front's in a mode to +2db then max volume becomes +16.
    My question is, the +18 applies to all modes with the exception of PLII and DD and DTS.
    If you do not increase any channels volume the max setting you will get in PLII is +15 and in DD/DTS is +9. Anyone know of the reason?
    Perhaps it's a results of the decoding. Ie in PLII you have it decoding the rear channel but in DD/DTS you have more channels being decoded (more channels = less headroom??)
    Cheers
    Michael
  2. Alexis
    Alexis Stunt Coordinator
    Feb 18, 2002
    94
    It is the same way with my 1602. I haven't had the chance to test the other denon models yet, but I can't figure out why this is the case either.
  3. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    It'a same on every Denon models I owned.
    Once any channel's "trim" is over "0" db then it will reduce the master volume by that same amount.
    It only makes sense,you are increasing the output of that channel,you can't get it for "free".
  4. MichaelWRX
    Jun 18, 2002
    9
    Yep but my question is more:
    Why is the max volume setting in PLII only +15
    Why is the max volume setting in DD/DTS +9
    Mchael
  5. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    On my Rotel the bass levels are compensated specially for those modes so I wonder if the bass is why those modes have a lower upper limit...either way you'd be deaf long before you reached plus 10 on a denon[​IMG]
  6. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    This is interesting...never realized that different sound modes have different sound volumes. But like Andrew said I would never go that high on my Denon 3802
  7. MichaelWRX
    Jun 18, 2002
    9
    Yeah. Not a biggie....Just an observation.....The additional sound dynamic of DD and DTS more than compensates for the lower max volume.
    Michael
