Dennon 3805 setup with polk speakers
Discussion in 'Speakers' started by james vaughan, Nov 6, 2005.
  1. james vaughan
    Oct 7, 2005
    45
    I was wondering what other folks have thier dennon set up for the speakers they are using. am using rt55i and a csi5 for the fronts and a pair of carver cinemas for surrounds and a DT 2500 for the 6th in back. The fronts sound great but seem to be lacking somthing in the rear end and am running plenty of power (seperate amps). Room size is 25 by 30. The polk csi5 blew away the dt for the center and am not sure if its because now the fronts match or what, but the dt sounded boxy almost tiny the polk was warm and full sounding had a more real sound to it compared to the dt. The dt 2500 put in the back brought the rear end of the system to life though. As I experiment I am wondering if its the size of the room and needing bigger speakers to fill it out more. Have been eyeballing the rti12 for front l/r but have been reading from you guys that this may not be necessary. For a sub I have svs pb12/plus2. The room has concrete floors with carpet over the top. Through some carpet up on the walls to tone down reflections and though it looks getto it helped alot. Ran the room eq with the dennon and didnt know if thier were any other adjustments I could make with this reciver that others have found that could help. The manual is not very useful.
    Thank yopu all very mutch for any thoughts.
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    RTi10s might be enouhg. That is a pretty large room. The 55s should be sensitive enough that with the right x-over they should do a decent job though. Have you calibrated with the auto setup?
  3. james vaughan
    Oct 7, 2005
    45
    yes I have run the auto set up. The Dennon also has a setting for flat normal and front. I think I left that setting as it came stock. Cross over is set to 80 hz. Am moving in a month to a new home and the theater room will have vaulted ceilings and is a little smaller. I guess my question is at what piont does the room become large enough to warrant tower speakers? And would the polk csi5 be able to keep up with the towers?
    Thanks agian for your input.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Towers have benefit no matter what size what room in all honesty. Not to say that there aren't sats that slay some towers. Really all depends on the sats and towers in question.
    I like the in bewteeners myself, large bookshelf with like 8" low end drivers.
    Really tough call, I am the type that is in favor of the same exact speaker in all locations.
