MikeMon
- Feb 8, 2005
Any thoughts on this projector? I have a dell card and this might be a good starter for me. Let me know what you think (or is there a better deal?)
Specs:
Dell 2300MP Projector
Affordable Performance Presentation Solution
Bright 2,300 ANSI Lumens (Max)2
Excellent high contrast ratio of 2100:1 (Full on/Full off)
4.7 lbs.; and only 3.1" high
Integrated zoom lenses and keystone connection
DLPTM DDR technology from Texas Instruments
Native XGA (1024 x 768) resolution with auto synchronization to UXGA (1600 x 1200)
Eco-mode option for quieter operation and to extend lamp life up to 2500 hours
Full connectivity — Supports PC, S-video, composite video, component (HDTV) video and RS-232 connectors
Supports full range of television and video standards, including NTSC, NTSC 4.43, PAL, PAL-N, PAL M, SECAM and HDTV (480i/P; 576i/P, 720P; 1080i)
Up to 3-year limited warranty3 with Advanced Exchange Service4 (90 days on bulb)
Includes all relevant cables, remote and a sleek carrying case which allows easy, no hassle transportation from room to room
Brightness
2300 ANSI Lumens (Max)2
Light Valve
Single chip DLPTM DDR technology
Contrast Ratio
Lamp
200-watt, user-replaceable P-VIP lamp; 2000 hours (2500 hours in Eco-mode)
Number of Pixels
1024x768
Displayable Color
16.7 Million true colors
Projection Lens
F/ 2.4 ~ 2.7, f = 28.0 ~ 33.6 mm with 1.2x Manual Zoom Lens
Projection Screen Size
Adjustable from 24.6" to 295.3" Diagonal
Projection Distance
1.2m - 12m
Video Compatibility
NTSC, NTSC 4.43, PAL (B/D/G/H/I/M/N) and SECAM (B/D/G/K/K1/L) compatible
H. Frequency
15kHz-70kHz horizontal scan
V. Frequency
56Hz-85Hz vertical refresh
Keystone Correction
+/- 16 degree (32 degrees)
Multimedia Audio
One internal speaker with 2 watt output
Power Supply
Universal 100-240V AC
Power Consumption
250 watts at full power
Noise Output
38 dBA (normal operation); 34dBA (eco-mode)
I/O Connectors
Power: AC power input socket
Computer Input: One VGA 15 pin D-sub
Computer Output: One VGA 15-pin D-sub
Video Input: One Composite Video RCA, one RGB/component and one S-Video
USB: One USB port
Weight
4.7 lbs (2.13 kg)
Dimensions (W x H x D)
10.9" x 8.1" x 3.6"
Environmental
Operating Temperature: 5o C- 35o C (41o F-95o F)
Storage Temperature: -20o C to 60o C (4o F to 140o F)
Humidity: 80% maximum
Specs:
Brightness
Light Valve
Contrast Ratio
Lamp
Number of Pixels
1024x768
Displayable Color
Projection Lens
Projection Distance
1.2m - 12m
Video Compatibility
H. Frequency
V. Frequency
Keystone Correction
Multimedia Audio
Power Supply
Power Consumption
Noise Output
I/O Connectors
USB: One USB port
Weight
4.7 lbs (2.13 kg)
10.9" x 8.1" x 3.6"
Environmental
