PatB
- Feb 23, 2000
I'm running into freezes whenever I try to delete files. I usually shift+delete just to save a step but I kept experiencing freezes when I would delete a large file or multiple files. So I tried going through the recycle bin hoping that it would make a difference. No luck. My first try after the emptying graphic came up the system froze. It's not usually a total freeze but it's annoying as anything. The last time it happened I hit ctrl+alt+del and it said that explorer was not responding. I wasn't using IE so it must mean windows explorer. Any idea what could be causing this?
I keep my PC spyware/virus free, my startup is clean and I've gone through all the usual scan disc and defrag steps. So any other ideas would be greatly appreciated.
Thanks.
Sorry, should have mentioned my specs.
P4 1.7
Win98SE
256DDR
40 GB Maxtor 7200
Thanks.
P4 1.7
Win98SE
256DDR
40 GB Maxtor 7200
