DefTech "Outriggers"
Discussion in 'Archived Threads 2001-2004' started by Steve_W, Dec 8, 2001.
  1. Steve_W
    Steve_W Agent
    Nov 13, 2001
    37
    Help a newbie out please....
    I just bought Def Tech BP2006TL's and they are very narrow speakers. It seems that there are 2 plastic "outriggers" that came with them for attaching either spiked feet or simply improving stability.
    The problem is that when I line up the "outrigger" in the groove on the bottom of the speaker, there are 2 holes in the outrigger but nothing to screw them into in the base of the speakers. It almost looks like to attach them I need to drill into the base?? Which I am certainly not about to do.
    They have a fairly decent manual I cant believe they didnt explain or illustrate anything about this..
    Thanks!
  2. Steve_W
    Steve_W Agent
    Nov 13, 2001
    37
    bump
  3. Bruce N
    Bruce N Second Unit
    Feb 13, 2000
    349
    My BP30s and the BP2002s I had before them came with the same setup. The included screws had very sharp tips and they screwed right into the bottom of the speaker. No problem.
    Bruce
