Definitive technology .
Discussion in 'Archived Threads 2001-2004' started by Raphael O, Jan 2, 2003.
  1. Raphael O
    Raphael O Stunt Coordinator
    Jan 1, 2003
    93
    Definitive technology BP 2004 pair mains.
    i have owned this set for 4 years now and am very pleased . - i am curious as to which other brands and model do these speakers compare to ?
    i have not really demoed much at that time and bought it off the bat quick.
    this will give me an idea where my speakers stand compared to others so when i upgrade - i will know what to audition and get.
    i also have a BP2X rears and C1 center .
    it is powered by a pioneer elite vsx 07 tx.
    tnx.
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Well, the design of the DefTech speakers is a bit different. They are bipolar - they fire sound backwards and forwards. This adds a depth/echo to the sound like being in a large theater or stadium.
    This adds a tone/flavor that takes a bit of getting used to, but then makes other speakers sound different.
    You really cannot ask: "What speaker is just above and below speaker XXX". This is like asking for opinions on ice cream or beer. Everyone has a different taste.
    When you are ready to upgrade, post your budget and ask: "I have $yyyy to spend. What should I audition?" and you will get a better response.
    If you want an upgrade opinion, go listen to the DefTech CLR 2002 center speaker. It is a large step up from the C1 and this single speaker will make a dramatic change to your system for movies, but maintain the important tone-match needed for your front 3 speakers. This center was the speaker that caused me to buy DefTech.
    Hope this helps.
