Definitive Technology BP1.2x Surround Speakers (1 Viewer)
Nemo128
Chris
These are brand new. I decided on Mythos Gems with their stands instead. They are black. The registration card is unused and still in the plastic bag.
Dimensions | (Metric) :9-3/16" W x 5-15/16" D x 10-1/2" H | 23.3 x 15.1 x 26.7 cm
Driver Complement :Two 4-1/2 inch high resolution bass/midrange drivers; Two 1 inch ferromagnetic fluid damped moving coil pure aluminum dome tweeters
Frequency Response :52 Hz – 30 kHz.
Impedance :Compatible with 8 Ohm outputs
Sensitivity :90 dB
Recommended Associated Amplifier Power :10 – 125 watts.
A/V Receiver Crossover Setting :100 Hz
Inputs :One pair of 5 way binding posts
Available Finishes :Matte Black; White
Accessories :Keyhole Hanging Bracket
Packaging :Two to a carton
Weight | (Metric) :9 lbs | 8.6 kg
Warranty :5 Years
I did toss the box out unfortunately, and I would prefer local drop off. I can bring them to you, no problem, or you can pick them up.
$250 for the pair.
Nemo128
Chris
I had another post for a brand new CLR2002 but I don't see it here.
Well, brand new Def Tech CLR2002 for sale, $350, contact me with any info or interest!
eathree
