Defaults for RP-91?
Discussion in 'Archived Threads 2001-2004' started by Mike Broadman, Oct 9, 2002.
  1. Mike Broadman
    Mike Broadman Producer
    Aug 24, 2001
    4,951
    I posted this in the middle of another thread in the software section, but this question is more fitting for this forum. Apologies to mods if it's too repetitive.
    Can an owner of the Panasonic RP-91 DVD player please tell me what the default settings for the TV type are (4:3 vs 16:9)? I tried playing an anamorphic DVD but it fills my 4:3 screen. My player was a floor model and comes with no instruction manual and the remote doesn't work.
    Is it possible to access that setting on the player itself without the remote? I could order a remote from 1-800-REMOTES, but it'll take a while before I get it and I would like to know if the DVD is defective so that I can try to return it.
    Thanks.
  2. Scott Merryfield
    Dec 16, 1998
    12,165
    987
    9,110
    The default screen type for the RP-91 is 4x3. Since this is a floor model, though, it's possible that it may be a returned unit, which means that any of your settings could have been changed by the previous owner.
  3. Mike Broadman
    Aug 24, 2001
    4,951
    Thanks, Scott.
    Do you know if there is any way to change the setting without using the remote?
  4. Scott Merryfield
    Dec 16, 1998
    12,165
    987
    9,110
    Mike,
    I do not know of any way to get into the setup mode of the RP-91 without the remote. There are no front panel buttons that allow for that function.
