Default size of new IE window (1 Viewer)
jeff peterson
Suddenly (probably kid related) when I click on a link and open a new window, it's opened in a minimized state. How do I get it to open full screen?
Camp
It should remember the last size. Try maximizing and close it. Open it again and it should appear as you left it.
Rob Gillespie
Open an IE window to the position and size you want then close the window but holding down CTRL at the same time.
Mike LS
Yeah, you have to manually size it the way you want it. Usually just hitting the maximize button and closing won't do it.
Rob Gillespie
Actually, if you hit Maximise, then CTRL and Close Window it does stay like it. At least it does with IE6 on XP.
Rob Gillespie
Pboley1
