Def Tech BP2X vs. BPX
Discussion in 'Speakers & Subwoofers' started by Andrew Pezzo, Jun 23, 2003.
  1. Andrew Pezzo
    Andrew Pezzo Second Unit
    Mar 17, 2003
    483
    I am trying to decide between the two, anyone ever compare these? Thoughts?
    For budget concerns the BP2X are better but I like the piano black finish of the BPX's. Another concern is since I am not using a seperate sub would the BPX's be better,(down the road I plan on wiring a sub with the surrounds). I plan on testing both in my HT but I want to hear what others have to say.
    My system consists of a Denon 3803, Def Tech P2006TL's (L/R), and Def Tech CLR2300 (center). I was using a pair of ProMontior 80's for surrounds but they just werent cutting it.
  2. RISUG
    RISUG Stunt Coordinator
    May 3, 2003
    179
    All I can say is which ever one you choose is gonna make for one hell of an awesome system.[​IMG]
  3. Andrew Pezzo
    Mar 17, 2003
    483
    Thanks. If you only knew what I have been through in the past few months in getting the "right" speaker.
