Def Tech BP2x question.
Discussion in 'Archived Threads 2001-2004' started by Gary.H, Jan 28, 2002.
  1. Gary.H
    Gary.H Stunt Coordinator
    Mar 26, 2001
    80
    How do the BP2X mount on the wall? I'm getting these soon but havn't looked at them closely enought to see how they go up. Do they come with a mount? How easy is it to mount them? Thanks. Gary.
  2. Marc S Kessler
    Marc S Kessler Stunt Coordinator
    May 8, 2001
    186
    You can hang them flat against the wall like a picture frame. We just put a screw into a stud leaving about 1/4" sticking out so you can hang the speaker.
  3. Gary.H
    Mar 26, 2001
    80
    How heavy are they?
  4. Marc S Kessler
    May 8, 2001
    186
    Since they're unreachable by me at this time I'll guess they weigh about 15 lbs.
  5. Shawn C
    Shawn C Screenwriter
    May 15, 2001
    1,429
    Yeah, there is a keyhole slot in the back. I just used a drywall anchor and left the screw out 1/4 inch...Just like everyone else says. This is what you get..
    [​IMG]
  6. Gary.H
    Mar 26, 2001
    80
    Do you set the bp2x as big or small on your receiver?
  7. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    Definitely small [​IMG]
  8. Shawn C
    May 15, 2001
    1,429
    Yeah, mine are set as small....
  9. Gary.H
    Mar 26, 2001
    80
    Back to hanging them. I'm sight impaired and not a real "handyman". What size screw would you use? I'm probably going to find a friend to help so I don't mess up the wall.
  10. Bob_A
    Jul 30, 2000
    876
    I hope the other guys can help you with that question...the dealer installed my bp2x's [​IMG]
  11. Scott-C
    Scott-C Supporting Actor
    Jul 23, 2001
    863
    I'm not sure about the screw size but I know I got pretty long screws - either 2" or 2.5" - to make sure the speaker was firmly bolted to the wall. I'm not sure about the weight, but I did exactly as others have done (screw into a stud, leave it hanging out a little bit) and it's very secure.
