Richard Goode
- Apr 11, 1999
I'am having a hard time figuring out the best place for the rear speakers. I have the BPVX/P speakers for the rear L/R channels. I currently have these speakers mounted at about 5 1/2 feet high on the side wall, and about 7 feet behind the listening position. They are mounted less than a foot from the rear wall. My other option is to mount them to side of the listening position about 1 foot behind the listening position there is no problem with height on the side walls. In the manual it states to mount them just behind the listening position. If any has any thoughts on mounting these speakers to the side or leaving them to side I would really appreciate some advice. The way they are mounted know it seems there is a gap between the sound. The distance between the the front speakers and the side mounted would be about 14 foot feet. Were as the distance the way the speakers are set up now are almost 22 feet. Thanks for the input. Richard Goode
