Def Tech 2006 owners--add a Sub?
Discussion in 'Archived Threads 2001-2004' started by Mac, Nov 25, 2001.
  1. Mac
    Mac Agent
    Feb 17, 1999
    42
    I have owned the Def Tech 2006's for some time now and love them. I have the sub out on my Denon 3802 split and hooked into my Def Tech 2006's LFE in, and do not have a stand alone sub. While the bass sounds pretty good, it does seem to be missing a little oomph. I have read alot of good things about the Def Tech 15TL sub--would this be a good addition to my system or would I not see to much of a improvement over the bass in the 2006's. Thanks.
    Mac
  2. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    Yes a quality external sub will be a very welcome addition to your HT...in particular, you will benefit from the extra output associated with boundary reinforcement of the lower frequencies. Basically ANY loudspeaker can benefit from the addition of a quality external sub.
    Good luck!
  3. John H
    John H Second Unit
    Nov 27, 1998
    472
    I would also recommend adding an external subwoofer to your system. Even though your Mains have powered internal woofer sections they can not compete with a quality well placed subwoofer.
  4. Bhagi Katbamna
    Bhagi Katbamna Supporting Actor
    Jun 1, 2000
    870
  5. Bob_A
    Jul 30, 2000
    876
  6. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    Bob, why don't you have a sub? I read that elsewhere.
    You rec'd it.
  7. Bob_A
    Jul 30, 2000
    876
    Adil, my speakers are all in the family room...at this point, I cannot get away with having an external sub!
