FredHD
- Oct 8, 2000
After moving into a 2 bedroom apartment, I finally have a dedicated home theater. Having moved it into a slightly smaller room than before and with a slightly different setup, I have a couple of problems I'm working on.
1. Surrounds
The surrounds have lost a little bit of their effect. Previously I had the seating right against the wall with the surrounds mounted on the same wall, pointed at each other over the heads of the viewers. They were about 68
inches above the floor.
Now the speakers are mounted on the side walls. They are now about 82 inches above the floor. If they are any lower, the door will be in the way whenever it is open.
The speakers were also maybe 1.5 ft closer together before. The seamlessness and "imaging" that I had before is not quite the same. I'm not really sure what to do to imrpove it. Any advice?
2. The Sub
At my old place, my subs volume was half way up and my reciever was set to -12. In the new room, I have to set it to -6 to get the same amount of bass. I think this is because the size of the room has changed. It is in the same corner of the room and facing the same direction as before. Is it the cahnge in room size that could have caused this effect. All setting other settings on receiver (speakers set to small) are the same. Any ideas?
Thanks in advance.
BTW, I have a diagram if someone could post it. I don'y know how.
JW
1. Surrounds
2. The Sub
Thanks in advance.
JW
