TimZ
- Apr 17, 2004
Decided to go with an SVS ( after reading all the raving you guys do about them
)Room is about 2100 cu ft 9ft ceilings. all sheetrock. 7.1 with medium sized Onkyo speakers ( got a 6.1 set at frys for $180 and got an extra surround back from onkyo direct). Yamaha RX-V750.
I can spend up around $800 if neceessary
looking at the
PB1-ISD
20-39PCi
20-39PC-Plus
even the PB2-ISD if you really think i should go that high.
I do an equal amount of music and movies ( slight bit more movies though, got some good bass ones i wanna try
I just really need input since there is no place for me to demo them.
And is there any real difference between the Cylinder and box ones?
looking at the
PB1-ISD
20-39PCi
20-39PC-Plus
