Dead Projector (NEC XG110) Help!!
Discussion in 'Archived Threads 2001-2004' started by al chaney, Jul 25, 2001.
  1. al chaney
    al chaney Extra
    Jul 31, 2000
    23
    MY NEC XG110 has now power, no lights, and no soung coming from the unit.
    Any technical help onwher I should look for the problem would be appreciated.
    Al
  2. John-D
    John-D Stunt Coordinator
    Feb 27, 2001
    198
    al,
    Also try this CRT Projectors Forum for input from very knowledgable and technical CRT owners and service people.
    Good Luck.
    The things we own end up owning us
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I assume you did not hear any exploding glass prior to this? Check your cooling filter to make sure it is clean and free of dust. Be careful not to stir up a lot of dust or else this could contaminate the inside of the projector (and the LCD panels). If you are not already doing so, make sure filter is always clean or bulb can overheat. Always use the correct power down sequence so the fans can cool off the bulb properly eg, never do a hard power down). . Unplug the unit for a couple of minutes then replug and try to turn on. (Make sure source is good of course).
    Report back your findings.
    orangeman
    Neil's H.T. Site
    (plus large selection of H.T.Links and movie images)
    [Edited last by Neil Joseph on July 26, 2001 at 08:35 AM]
  4. RobertR
    RobertR Lead Actor
    Dec 19, 1998
    9,766
    197
    9,110
    The XG110 is not an LCD machine.
