DDS & HDTV lineup!
Discussion in 'Archived Threads 2001-2004' started by GaryCT, Mar 5, 2001.
  1. GaryCT
    GaryCT Auditioning
    Jul 5, 2000
    8
    I just got word that my backordered Sony SAT-HD100 HD tuner has arrived! I'll be signing up for Direct TV and will have the best sony dish installed as well. What channels have the best quality and which have the most programming?
    I'm not familiar with "Cinemax Multimax", any good?
    Is HBO or Showtime best? Is the total choice platimum option overkill?
    thanks so much.
    Gary
  2. Matt_W
    Matt_W Auditioning
    Mar 27, 2000
    3
    At the absolute least you have to get HBO to enjoy the HD on 509.
    If you are a first time subscriber, you should get everything for at least a month so that you can settle into a programming plan after sampling it all.
    If I remember right you can change as frequently as you like, so enjoy!
