DD LFE boosted 10db in receivers, what about DTS?
Discussion in 'Speakers' started by Brian_cyberbri, Jul 21, 2005.
  1. Brian_cyberbri
    Brian_cyberbri Stunt Coordinator
    Dec 30, 2004
    202
    In reading up on subwoofers, I discovered that receivers boost LFE 10db, which is why Avia tones are -10db to compensate, and why DVE (without the -10 compensation) gives wrong results.
    So I was wondering about DTS. If I calibrate to 0db sub setting on my receiver for DD using Avia, does that mean I need to put the DTS sub setting at -10 to be the "same"?
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Should be the same for DTS.
  3. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    Next question: Why do AVRs boost the LFE 10Dbs?
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    The recordings are that way, so receivers are designed to compensate for this by default. Why it is that way, I couldn't tell you. I know I read a reason why, but I can't seem to remember it, probably because it really isn't all that important due to the fact that the compensation is already present and the typical consumer would not know the difference.
    The one place it can come into play glaringly is with hi-res audio via analog - the +10dB is not present because the signal is passed via analog and does not pass through the receiver's bass management circuitry, so the appearance is that bass is lacking.
  5. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Has something to do with having more gain available on the DVD LFE track, or something... [​IMG]
  6. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
  7. rob-h
    rob-h Second Unit
    Jul 6, 2005
    263
    It turns out the secret article is really a secret 404 error! [​IMG]
  8. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
  9. Edward J M
    Sep 22, 2002
    2,031
    Sorry guys - I found the article and posted the hotlink - not sure why there was an error but FeisalK's link works - thanks.
    Ed
