DD/DTS probelm with Denon 1802
Discussion in 'Archived Threads 2001-2004' started by ChadM, Dec 10, 2001.
  1. ChadM
    ChadM Stunt Coordinator
    Jun 5, 2000
    234
    My brother got the Denon 1802 and a set of Boston surrounds on Saturday. When we got them home we commenced to hooking everthing up. All we had to hook up is the TV, DVD receiver and speakers. My question is: we have sound, however, the DD/DTS lights will not come on, what is wrong?
    Help!
  2. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    1,770
    14
    Jeremy
    you have a digital cable right? make sure that in your DVD player setup menu, that you have the Digital bitsream enabled.
  3. Brian Johnson
    Brian Johnson Supporting Actor
    Oct 21, 2001
    739
    Also, in the system setup for the receiver you have to tell it which way you have the dvd hooked up- either through the digital or optical input. I have the 1602 but im sure its similar- but check the dvd player setup also like the last post advised.
  4. ChadM
    Jun 5, 2000
    234
    Jeremy,
    Damn that my be it. We spent a good amount of time drilling holes, moving things and so forth. At the end of the day I was exhausted and then I could not get that light to come on and I got frustrated and not thinking clearly. Thing is, my brother was really happy with the way it sounded. I will try that and report back here on Saturday (I am out of town).
    Johnson,
    I did that.
    Thanks to both of you.
  5. PeteD
    PeteD Stunt Coordinator
    Mar 13, 2000
    110
    Look for a setting that sets input..
    First, you need to assign the digital input to a source.
    IE Assign Optical 1 to DVD/LD
    Second, and I can't really remember what the button is called, is to change detection mode (think it's called input). I think the choices are:
    5 Channel
    Analog
    Dolby Digital
    DTS
    Auto
    Make sure Auto is selected. I think it will light up the auto pilot light, and there should also be a Lock light.
    Let me know if this helps, and if you need specifics let me know and I'll check when I'm home next. I have the 1801 which must be similar.
    Pete
