DD/DTS DVD player with smooth layer change?
Discussion in 'Archived Threads 2001-2004' started by Al_S, Mar 15, 2002.
  1. Al_S
    Al_S Second Unit
    Nov 30, 2000
    446
    Are there any good DVD players with DTS decoding built in that have enough memory to handle layer changes smoothly? I'm looking to spend less than $500.
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Al although the lenght of the layer changer can be affected by the player most of ithas to do with where the layerchange is located on the disc itself. What I mean is if the layerchange is located in the middle of dialog or an action scene you'll notice it every single time. If however its located between scenes its much less noticable...unfortunatly for some reason DVD authors are still putting layer changes in bad spots[​IMG] All that said there are some players that are faster then others. The fastest players are those that use a DVD-ROM transport like the Apex players...unfortunalty those players also tend to have poor image quality compared to the normal units.
  3. Ken Seeber
    Ken Seeber Supporting Actor
    Nov 5, 1999
    787
    2
    Denon's DVD players have memory buffers to eliminate or minimize noticable layer changes. You'll need to check Denon's Web site to find which model has onboard DTS decoding.
  4. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    i hear NUON-equipped players also have memory buffers that'll rid layer changes
  5. Ron Alcasid
    Ron Alcasid Stunt Coordinator
    Apr 11, 2000
    168
    Al_S, you might check the Denon 1600. It has all the features you requested. No one has actually seen one so it's actual performance is unknown. It's slightly more than you want to spend at $549 SRP.
  6. Al_S
    Al_S Second Unit
    Nov 30, 2000
    446
    Thanks guys, I'll check out the Denons. Any others?
  7. David Wood
    David Wood Auditioning
    Feb 25, 2002
    3
    The layer changes with Kenwood's newer players are sloooooooow. DVD-ROM drives (and those players, like Denon that have such drives) are much faster.
  8. Jeff
    Jeff Supporting Actor
    Jun 30, 1997
    947
    Of course the trade off is, with Denon you get glitches.
  9. Jeff Pryor
    Jeff Pryor Supporting Actor
    Mar 5, 2002
    653
    I've got an RCA model I purchased in '99 with a DTS decoder, and this thing is very fast with layer transitions, about a 1 second pause.
