Scott W.
- May 20, 1999
Could Dolby Digital EX also be called DD 6.1? Cause isnt the 'EX' an extra 'centre rear' channel? Info would be appreciated. TIA!
Scott
Scott
Chad's explanation is right on the money. The "5" in "5.1" refers to five discrete channels of audio: left, right, center, left surround, rear surround. Dolby Surround EX does not have an additional discrete channel, so calling it "6.1" would be incorrect.
This hasn't stopped a lot of hardware makers from claiming that they make "6.1" and "7.1" receivers and processors. But technically, the only 6.1 format out there is DTS-ES 6.1 Discrete. And there is no -- repeat, zero -- 7.1 format at all.*
M.
*Unless you count SDDS-8, which is strictly for use in commercial theaters.
Remember that our perception of the location of sounds behind us is far less accute than for those in front of us.
This may be true but using logic 7 on the lex which is the only 7.1 discrete "format" so to speak. The independent sounds coming from the BACK l/r speakers are very easily noticeable.
