DC restoration in Sony 34HS510: service menu
Discussion in 'Displays' started by AngeloNA, Apr 2, 2004.
  1. AngeloNA
    AngeloNA Agent
    Aug 9, 2003
    30
    I've read in this forum that one should set the YDC or Y-DC setting in the Sony service menu to "0" to improve the retention of black levels. Looking through the service manual, however, I can't seem to find this item. Does anyone know if there's a new name for this item, or is it still in there and I'm not seeing it?
  2. Chad B
    Chad B Stunt Coordinator
    Jul 5, 2001
    221
    There should be the YDC and/or DPIC (for dynamic picture). They have a similar end result.
  3. AngeloNA
    AngeloNA Agent
    Aug 9, 2003
    30
    Well I can't seem to find either in my 34HS510. I read elsewhere that these items have been taken out of the latest Sony's. Don't know if I believe that, but I can't find them to disprove it! Anyone know anything about this?
  4. Chad B
    Jul 5, 2001
    221
    I just calibrated a brand new Sony 57WS550, and it's true that the service menu was significantly changed from previous Sonys. For example, all the color decoder controls were in a new submenu called "MCP." My literature was for the previus service menu, so I had to experiment and hunt a little in the new submenus to find what I needed. Turned out that everything was there, but in different areas, including the controls in question.
    In the WS510, the DPIC control is in the 2150P-3 submenu. I'm not sure if the HS510 has a different menu than the WS510, but there's an easy way to check. Just see if there's a submenu named 2150P-3. If there is, then you have the familiar service menu. If there isn't, than it might be the new menu. If you have the new menu, I should be calibrating another one in about a week, so I can let you know where it's at then.
  5. AngeloNA
    AngeloNA Agent
    Aug 9, 2003
    30
    Thanks for trying to help me out. The color decoder items in my model are in the 2170P_4 submenu. And unfortunately, there is no 2150P_3 submenu. If only the service manual had some descriptions for the items!
