DC Arcade Stick to other platforms - possible?
Discussion in 'Archived Threads 2001-2004' started by Iain Lambert, Mar 4, 2003.
  1. Iain Lambert
    Iain Lambert Screenwriter
    Jun 7, 1999
    1,345
    I'm in the process of buying a second-hand DC Arcade Stick off someone, so I can get some decent control in Ikaruga. However, with things like Marvel Vs. Capcom 2 EO, Soul Calibur 2 and indeed Ikaruga coming to the Gamecube, I'd love to be able to get a converter to use it there, and it would certainly improve the playing of Mame on the PC as well.
    So, does anyone know of any DC Stick -> Other Things converters? I know PS -> PC exists, but I've not found any DC ones.
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    There's this converter for the PC but I can't find anything to let you use a DC controller on the PS2.
  3. Iain Lambert
    Jun 7, 1999
    1,345
    Thanks for the link - I'll keep searching for a Cube option as well, which is the main one I need.
  4. Romar Armas
    Romar Armas Second Unit
    Oct 17, 1999
    276
    Check out www.shoryuken.com those guys are hardcore and have done tons of conversions.
  5. DaveGTP
    DaveGTP Cinematographer
    Jul 24, 2002
    2,096
    I did a lot of research on DC converters. The best converter for Dreamcast I found was one that converted Saturn, PSX, and PC keyboard to Dreamcast (See ign coverage here: http://gear.ign.com/articles/59206p1.html
    There is also a dream connection 5-in-1 that takes a memory card as well, but it is near-impossible to find (there is one place in the UK that has them). If you find something that will convert Dreamcast to Gamecube or vice versa, yell out, I would jump at it, but I don't think you'll have a lot of luck. =0 Good luck!
