Dayton Titanic sub vs. Hsu STF-2
Discussion in 'Speakers' started by NileDB, Jan 9, 2004.
  1. NileDB
    NileDB Extra
    Jan 7, 2004
    21
    Both of these are in my price range and get good reviews here. Has anyone done a direct A/B comparison? If so, please share your thoughts. Does the Paradigm PDR-10 compete with either?
  2. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
  3. Sasha_G
    Sasha_G Agent
    Mar 7, 2002
    45
    From HSU Research:
    The manufacturer of our subwoofer makes subwoofers for numerous famous large subwoofer companies. The procedure they followed in manufacturing the STF-2 is identical to the procedure they used in manufacturing all the other subwoofers. The only difference is the other subwoofers are not capable of producing such high SPL in the low bass, and thus air leaks are not as obvious. We have instructed them to follow special testing procedures for our subwoofers. All future productions will not have this issue. Only about 1% of owners have reported this issue to us or on internet forums.
    If you have an air leak issue, there are a few options available:
    1. Fix it yourself. This is something very simple and easy to do, and it results in the least down time. You can get it to work properly almost right away. This in no way voids the warranty. See below for instructions.
    2. If you purchased it from CompUSA, you can bring it back for an even swap with another unit. If they are out of stock, you can use it until they have it back in stock and then you can bring it in to swap. Have the CompUSA sales person write a note agreeing to let you take it in to exchange at a later time if they do not have stock.
    3. We can mail you a replacement driver. The down side to this is the time it takes to ship a driver, and that we won't have replacement drivers for a month because we are waiting for them from China. Please call and ask for tech support at 1-714-666-9260.
    Repair instructions:
    1. Fix it yourself. From the units we’ve examined, firmly pressing around the outer perimeter of the woofer will seal the leak.
    [​IMG]
    If pressing makes the air leak go away, apply silicon sealant around the outer edge of the woofer, as shown in Picture 2. White wood glue was used only to make the glue easier to see.
    [​IMG]
