Mitch N
- May 11, 2004
I have a bit of a dilemma. I have the parts to build another MKII 10" sub for HT use. I'm debating on going with a PR or going with a port. The problem is that the port length is too long. The ported enclosure I want to make is a 1.41Cu Ft box with a 19.3"x3" vent, tuned to 27hz.
A quick call to Parts Express asking about PR's, and they recommended a 12" Dayton PR Part # 295-192 with no added mass. But they couldn't tell me what it was tuned to. Just a general rule of thumb that the 12" PR mates well with the 10" MKII. They said I could go up to 150g of added mass if I wanted to try it.
What do you think?
What do you think?
Code:
Here are the specs for the MKII 10"
Fs 28.
Qms 9.547
Vas 38.09 L
Xmax 16 mm
Xmech(est) 24 mm
Sd .034 sq. m
Vd(calc) 538 cc
Qes 0.427
Re 2.467 ohms
Le 2.48 mH
Z(nom) 4 ohms
BL 11.74
Qts 0.407
1-W SPL(calc) 85.1 dB
