Antony
- Oct 31, 2002
Hello everyone,
It's time for me to start planning my DIY sub. I was originally planning a Shiva in the Adire vented alignment (will be about 89.25L internal volume without taking into consideration volume of bracing and driver) using an AVA250 plate amp. The above is all due to size considerations and WAF.
We use the system for 99% HT and 1% music.
My questions are:
1. How does the Dayton DVC compare to the Shiva mk III? I don't have time today (am at work) to compare the specs on each, before the PE special pricing ends.
2. Have people used the Daytons in the Adire alignments (if so, I'm assuming that they're very similar drivers).
3. The exterior dimensions will be about 28w x 19h x 14d, using 3/4" MDF, and a double layer on the side where the driver mounts. I originally planned a front-firing design (using one of the 28x19 sides as front). Will it make a difference to build it down-firing, using one of the 19x14 sides to mount the driver?
Thanks in advance for your help,
Antony
My questions are:
Antony
