Wayne Ernst
- Feb 24, 2002
Update: I checked the measurements this morning when I got to the house. The distance between the mantle and the ceiling was 1/4" greater on one of the sides. The large center square panel is the panel that the guy thought was sloping down a bit. I could only confirm that by holding a straight edge across the bottom of the moldings. I could then see what he was talking about - but, with the naked eye and without the straight edge, it's nearly impossible to tell.
I then took off 2 pieces of the center panel molding, cut new pieces and installed them. The straight edge confirms all is good now. However, to the naked eye, one really can't tell that anything has changed. But, the customers are good customers of mine and do supply me with frequenty business. It was just easier to replace the few pieces of molding than discuss it any further.
Original message:
I spent parts of the last few days installing a set of moldings to make the area above a fireplace more formal than the drywall that was present before. After installing the moldings, I carefully caulked the seams, primed the surfaces and applied 2+ coats of paint.
Tonight, I get an E-mail from the client indicating that the moldings appear crooked to him. So, tomorrow, I guess I'll have to avoid taking a day off and instead, re-work the moldings to behold the eyes of the customer.
Here's a picture of the work that I completed:
Original message:
