Johnny_M
- Apr 6, 2004
I have 3 little dark spots on the inside of my 42" samsung screen. they are not on the outside as cleaning does nothing. they are only visable in brighter scenes, but are always there under every input mode and are starting to bother me. I've been searching the forums and am guessing its dirt that can easily be removed, but I have never takin my set apart before, what should I expect? It looks like there are several screws going around the tv and looks as if the top half of the tv will just lift up once they are removed. is there anything else i should be aware of? wires or cables that might be holding the display down?
any help would be great, if anyone knows where instructions are available even better. also, are the spots likely on the screen itself or the mirror? and what product would you use for the cleaning?
Johnny
Johnny
