Johnny C
- Jun 5, 2001
Okay...So I bring home my new Wega 32FS16 only to find that there are some barely visible dark vertical bars on the left hand side of the screen (like most of these problems, almost unnoticeable until they're seen, then you just can't take your eyes off of them). There are a couple of them, running from top to bottom, one is about 1/4 inch and the other 3/4 inch wide, a couple of inches in from the left. They're visible using all devices...cable, dvd, and vcr.
An exchange isn't a problem, but with the number of wega picture problems I've seen posted here, I'm concerned I could get an even worse replacement. Other than this problem, I am very pleased with the picture.
What exactly is causing this, is there any way to fix it, or should I just go ahead and exchange the thing?
cheers
John Carta
cheers
John Carta
