DavidEC
- Feb 13, 2001
If you are a fan of the TV show 'The Prisoner' I highly suggest that you check out the A&E release of the show "DANGER MAN", which shows our 'NUMBER 6' as spy John Drake. The set has the first six hour long shows.
I picked up 'SET 1' from DeepDiscountDVD.com for less than $20. http://www.deepdiscountdvd.com/dvd.cfm?itemID=ANE070317
The black and white images are very sharp and the audio is clean. When you take into account the 35+ years old age of the source and most likely was not even thought of storing for this long.
Of the four shows that I have watched on the two DVD's only one time did the image seem not to match the audio and I feel that the original source must of skipped.
I do hope that A&E releases at least the show from the "Danger Man" series called the 'Prison'(I think that was the name) where John was sent in to British Spy from a city of retired spys... which you could say was an early version of the 'VILLAGE' later used in the 'PRISONER' series.
--David
--David
