Kevin Byrnes
- Feb 25, 2004
I just purchased a JVC HM-DH30000U D-VHS recorder/player for $200.00 without the remote from a Major retailer with a 5 yr warranty. Can anyone tell me if this unit will work with my Samsung SIR-TS360 HDTV receiver. The Samsung has DVI, Component, and RGB outputs, but the JVC seems to only have the cable type coax connections, and a firewire input. Does this unit accept a signal from the ant in, or is there an adapter for the RGB, or DVI to firewire?? I'm so confused!!
